Heater not working in my truck....
Old 12-15-2007 | 06:27 PM
Smoke346's Avatar
Default Heater not working in my truck....
Just curious if anybody out there has had a similar problem with the heat not working in their truck. BTW, my truck is a 2000 GMC Sierra. Any help would be greatly appreciated so that I might avoid the dealer on this deal...
Old 12-16-2007 | 08:02 AM
Grumpy5.3's Avatar
is your coolant jug full??? if you have a coolant leak, you will lose heat.
Old 12-16-2007 | 09:45 AM
Make sure you dont have a restriction in your heater core. I pulled each line off and ran the water hose through it. It can stop up where the rubber hoses attach to the core.
Old 12-16-2007 | 06:22 PM
Smoke346's Avatar
i warmed the truck up to operating temp and felt the heater hoses, as I had suspected after thinking it over, the outlet was cold. So my plan was to remove the hoses and try to backflush the core. When I left work today, whatever was causing the pluggage decided to free itself and I now have heat, although not as hot as it usually is. So when I get a day off I will get it professionaly flushed and cleaned out, its way overdue anyway. Thanks for the input.
Stainless Works
04-10-2016 04:34 PM
85SS/85GN
08-07-2015 04:30 PM
Stainless Works
08-04-2015 12:56 PM
atxlt
07-20-2015 11:06 PM
Offroadunleashed
07-20-2015 02:25 PM
Quick Reply: Heater not working in my truck....
