HELP- 12v Light soure. Pod. Gauge.
I'm trying to wire up my gauges and I'm not sure where to find a 12v Light source. I'm trying not to splice into any of my wires so I bought one of those "Add-a-line"(by buss fusses), which takes power from your fuss block. I have found a 12 ignition switch and a 12 light switch that comes on with the head lights but I can't find a 12v source that varies with the dash lighting. Not sure if you guys know if there is a 10amp fuss that I could plug into that varies. If I have to I can splice into a line.
I have one more question. When you guys added a full gauge pod did you have to cut up or put holes into the factory pillar in order to run you lines.
dantheman1540
02-24-2016 09:56 PM
carid
10-28-2015 08:24 AM
carid
10-01-2015 09:22 AM
