Help with 5.3 injectors upgrade!
I have a procharger tuner kit for a 2007 classic 5.3 and need 44lb injectors
to make it work, problem is no one can tell me what injectors would be best for a direct connect with the engine code M. All info. would be great!
Try the GM/Delphi 8.1 MARINE Injectors, they flow 43.82 lb-hr and are a direct fit into the 4.8/5.3/6.0 engine. Like any injector you will have to modify the tune for IFR, Pulse width, etc but it is doable by any good tuner. the part number is 17113739-GM or 25176061-Delphi
GrooveCityZ71
08-31-2015 12:05 PM
bbowerman
07-26-2015 10:57 PM
maxspeed05V
07-19-2015 07:08 PM
