Help with coolant leak.
Old 11-27-2011, 11:50 AM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by TURBHOE
Found it, A factory coolant hose that goes from the throttle body to the radiator. It clicks into a holder and some how got knocked out and was sitting on the belt. It had a tiny tiny pin hole. Just enough to make a huge mess but small enough to drive every where. Lol. I spliced it with a barbed fitting. Should be good to go. No I have to clean all the mess the antifreeze left behind.
Good deal! Yes, it clips up under the stock air cleaner tube. If you have an aftermarket Cold Air Intake you will have to secure it with another methoed.
Old 11-27-2011, 11:52 AM
1FastBrick's Avatar
BTW a self serve car wash works great for messes like that... just stay away from electrical connectors and the Air intake system...
Old 11-27-2011, 03:22 PM
TURBHOE's Avatar
On mine it clips to the upper hose. It's never fallen before. I put it back on and put a zip tie on the ends to make sure it stays put.
Old 11-27-2011, 03:29 PM
nonnieselman's Avatar
I always zip tie that lil hose. Its happened to me before.
Old 11-27-2011, 05:42 PM
TURBHOE's Avatar
This was my first time for it to happen. I'll be sure to zip it up if I remove it for now on.
6.0l RST
11-23-2015 11:30 AM
bearden86
26
11-15-2015 03:58 PM
sTNT971
09-26-2015 04:22 PM
custm2500
09-08-2015 05:53 PM
the owl
09-04-2015 04:09 PM
Quick Reply: Help with coolant leak.
