help me build my truck!!! (what would you do thread)
#21
these are my plans as of now
this turbo kit HAS ANYONE USED IT https://www.performancetrucks.net/fo...d.php?t=435283
and doing a forged 6.0L w/ turbo cam and 4l80 and converter... then do heads later but will have after market springs in them now
I've seen those kits, I hear there badass, . Man, that sux what happened to your Lightning, I'm pretty sure Precision is gonna tell you nogo on rebuilding that turbo after seeing it. The only reusable piece on it is probable the exhaust housing. Everything else on it was been too hot to be reused.
As far as my kits, check around on the forced induction section, a couple guys running them that hangout in there. I will make ya a heck of a deal on a MPT76 kit with a 3 1/2" down pipe and 40mm JGS WG. That on a 6L and 4l80e in that truck should get you about where you want to be
#24
Location: Where our street cars are faster than your racecars..Mississippi
what do you think i could get out of a STOCK lq4 and a 76mm turbo front mount with a good tune??
hp?
psi?
et?
i have enough to turbo it with a stock motor and build a 408 with nitrous and no turbo
what do you think i could get out of a 408 with prc 2.5 heads(will get different ones later) and a 250 shot
hp?
et?
hp?
psi?
et?
hp?
et?
