help passeger pacesetter install!!!
Fellas need help so far i have the driver side header in but the passeger im havin a hard time it not go in, try both from top an bottom from bottom the egr block hits the frame, an the trans cooling lines also in the from top just the trans lines....
11 Second Club
I told him the same thing in PM, try removing the spark plugs and heat shield. The passenger side on mine slid right in, it was the driver side that I had to fight with... weird.
With the truck high enough in the air, mine slid right in from the bottom, kinda had to wiggle the driver's side around the steering shaft but it went in from the bottom too.
I did mine the dr side slide in like some warm apple pie. lol, the pass had to use a little muscle. It help that the heat shield was not on. Wonder if he got it put together? I seen (if its the same person) posted on sss the exact same question. One person said to remove the wheel well and slide it in that way, to much work for me.
