HID fog lights - anyone melt the housing?
Old 12-21-2005, 11:58 AM
tbyrne's Avatar
Default HID fog lights - anyone melt the housing?
I'm thinking about replacing the regular fog light bulbs in my '05 Sierra with a set of 6000k HIDs. I ran these in my Suburban but they were mounted in a set of modified PIAA 40 series driving lights with glass lenses. Has anyone done this mod with the stock fog lights/lenses and if so, how are they holding up? I'm a little concerned with melting them.
I know someone might want to write that fog lights aren't supposed to be used all the time, putting HIDs in will blind people ect, ect... I'm doing it for 1 - looks. The 6000k low beams and fogs look awesome (main reason for doing this) and 2 - the light output is so much better and they won't blind others if aimed properly.
Old 12-21-2005, 12:13 PM
Fogle07's Avatar
i put some bulbs in my fogs one time that where suppose to look like hids and they melted the housings. i changed them out with some blue ones and they worked fine after that. i think it will be sweet with hids in the fogs.
Old 12-21-2005, 01:38 PM
el_cabby's Avatar
I have done the silverstar hi beam in the fog lights on my 03 with no problems so far.
Old 12-21-2005, 02:13 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
2toneblown had HIDs in the fogs also on the silverado style fogs and didnt havea problem that I know of and your fog are alot bigger than the old style fogs.
Old 12-21-2005, 03:24 PM
tbyrne's Avatar
Hum... I guess there is only one way to find out for sure. I'll have to install a set tonight. If I see a liquid plastic trail behind the truck I'll know that it isn't good
Old 12-21-2005, 04:01 PM
04BlackSilverado's Avatar
Let us know how it comes out!
What kit are you using, I'm intrested in doing a kind of inexpensive HID for the Fogs and Lows in mine as well.
Old 12-21-2005, 06:24 PM
JimS's Avatar
There's an inexpensive HID?
Old 12-21-2005, 06:28 PM
1slow01Z71's Avatar
400 bucks is about the cheapest you will find a kit sylvania xenarcs and the XeSight system which is what I have
Old 12-21-2005, 06:58 PM
tbyrne's Avatar
The stock fog light bulbs are an H10 but I beleive they are supposed to be able to cross to a 9005. The 9005 will go in and turn a little but they don't really lock into place. One bump would drop them out. I might need to locate a 6000k H10 HID kit.
I'm working with a kit with Phillips ballasts. The kits now are cheaper than they were a few years ago. I remember when they were $700.+.
Old 12-21-2005, 08:15 PM
ChevyMan23's Avatar
There shouldnt be any reason for them to melt the housing i wouldnt think....my HID's burn a hell of alot cooler than my factory headlights....
Quick Reply: HID fog lights - anyone melt the housing?
