HIDs
HIDs
.......I bought a pair of Taiwanese Denali headlights, and two HID conversion kits awhile back, and finally got around to installing them. I decided to start cleaning up my mess, and when I opened the box that the HID kits were in, it turned out that I bought them in 2005. Damn, I'm slow.
......Anyway, the low beams are great. Nice cutoff, and the whole lit part of the road is bright white, just as I hoped it would be.
......The high beams are a different story. The spot starts at the low, or closest point, right in front of the truck. It seems to go pretty far down the road, it could go farther, but I can't raise them any higher because the lows are as high as is safe. The problem is that the close part is overwhelming the far part. It would help if I could cut off the low part of the spot.
......Is a not too great high beam standard in the Denali projectors, or is my crappy-ish high beam a result of my saving money on non-OEM parts? I wouldn't think that it is the bulbs fault, because they work so well in the low beams.
Sorry,can't help you on the hid's but,I do got a question...What rear wing you installing?I mean now that your trucks gonna be "ricer!".
Jfwy....Mike,stop screwin around with appearence mods and get the fuel system squared away.
Well,I guess there not really ricer.Jus sorta "riceresk"seems ever since they got cheap all the fart boxes around here havem.Fyi.I have a set for my camaro but,since they dont make it faster its considered a back burner project.Good luck though and for the sake of everyone that may encounter you adjust them correctly.
I'm definitely a sleeper and stealth kind of guy, I'd never allow my beams to purposely be annoying. Here is a sample of how good the low beam cutoff is. For some reason this out of focus pic best shows the pattern:
And here is my best pic of the high beam pattern. After seeing the pictures, I realize that the high beam is just too low, I can't raise it any because the low beams are as high as possible without shining in oncoming driver's eyes.
Any comments from people with Denali projectors about the high beam aim?
You consider combining both to get better distance light.Maybe stock Denali's have them tied together when high beams are used?
Good fog lights would get you a lil more distance.I agree though the current configuration looks too low.
