high oil pressure
Old 12-17-2006, 11:46 AM
TXsilverado's Avatar
Default high oil pressure
???is that a bad thing.
i swapped my 5.3 for a ls1 yesterday. i reused the ls1's oil pump. i never payed too much attention to what the 5.3 oil pressure was but i know it wasnt anywhere near this high. its hitting the 3/4 (60psi i think) mark on my pressure guage at idle. when i romp on it it gets a little past 80 psi and when i let out it takes a while for the needle to settle back down.
is this normal or do i need to throw my 5.3 oil pump in? or is it something else
Old 12-17-2006, 12:03 PM
onebadrubi's Avatar
have you checked your oil level?
Old 12-17-2006, 12:23 PM
ranwalk's Avatar
I'm guessing your oil pressure sender is bad. Did you use the one from the 5.3? If not, swap them and see if it changes.
Old 12-17-2006, 04:55 PM
9 Second Truck Club
tarinitup's Avatar
Mine has been doing the same thing for about a year now. I thought that was the normal pressure.
Old 12-17-2006, 05:33 PM
i called my buddy that the motor/pump came from and he said thats the way it ran in his car since the day he got it. atleast we know that my motor isnt starving for oil
Old 12-17-2006, 05:52 PM
TarheelZ's Avatar
My oil pressure has been 60 psi @ idle and 80 psi under throttle since I bought it 4+ years ago.
Old 12-17-2006, 06:09 PM
chevyguy7802's Avatar
My 5.3 idles at 50 psi and runs at 60psi but when i get on it pegs out, all my buddies trucks are the same
Old 12-17-2006, 06:50 PM
LS1TRUCKGUY's Avatar
same here.
Old 12-17-2006, 10:19 PM
Mine idles around 36 psi. It gradually goes up as the rpm's rise.
Though I think this is normal on the 6.0L engine.
Congrats on the motor swap Stewart!
Damn, you did that fast.
Jim
Old 12-17-2006, 10:20 PM
Question
Now.....how does it run???
Jim
Quick Reply: high oil pressure
