Hobbs switch tell me how it works
Baltimore Whore
And the proper way it needs to be hooked up.. I have heard about them. What how, where do they get hooked to.... Any info on this is a plus. It seems that I may be running out of fuel up top, might be in the tune,but might need to run another pump on a switch.
Thanks all
John
Thanks all
John
Moderately Differentiated
you'll simple put a another fuel pump in that is triggered by a boost switch. When that switch reaches a particular boost level that you have set, it will closed a set of contacts that will power a relay that will close a set of contacts that are rated to handle the amperage of the pump.
If your pressure/boost switch(Hobbs Switch) is rated to handle the amperage of the pump then you won't need a relay.
Baltimore Whore
Yes this was his suggestion.. Might be able to tune the prob out, but duno, I have to talk further with him.. I am running a inline 255 now.. I might run a bigger pump intank. My question is.. If I put another intank in, the same size what will this solve, if they are flowing the same. I take it I am running out of pressure, not flow??
John
John
from the little bit of reading i did on them it looks like you can also hook them up so they kick on if your fuel pressure drops below a certain PSI too.
they seem pretty cheap im just not sure how you hook them up. wiring is not my specialty.
