horrible noise, and annoying..
Old 11-10-2005, 01:41 PM
nonnieselman's Avatar
well i just got home from kansas city, KS. and went by my parts store. went ahead and got the HUB. yea TX thats almost what mine does. but it doesnt matter how warm or cool it is.
im fixin to go slap it on and hope thats my problem.
IF not there went $165. but atleast i can take it back...
be back in a few!!
Old 11-10-2005, 01:44 PM
TXsilverado's Avatar
The hub is pressed into the wheel bearing. On the earlier vehicles the hub could be pressed out of the bearing and the bearing replaced seperately (although as tech I've found it better to replace the bearing and hub together...9 times out of 10). Now they come as a bearing and hub assembly...so basically they are the same part.
if i replace the wheel bearing and hub together will i need to have my truck re-aligned. its fixing to be winter and i dont feel like listening to it.
Old 11-10-2005, 01:59 PM
i dont see why you would?? but i dont know.. i found them toyos for $466.96 shipped. hehe gettin better.....
Old 11-10-2005, 02:30 PM
too bad you dont live around me. i would be able to get them for 460 mounted, roadforce balanced, lifetime free rotate blah blah blah
Old 11-10-2005, 06:47 PM
u stink!!!! oh well. i can mount them and balance them myself. i know someone that has the machines. Life time rotations? its never worth the time and gas to take it somewhere and get my tires rotated. i live to far from anyplace that does that. and it only takes me bout 5 mins to rotate them with a couple friends helpin.
Got the hub in and took it for a spin......
No more noise!!! Finally.
Now to get some tires...
toyos and swamplites
Old 11-14-2005, 05:09 PM
ttt .
Old 11-14-2005, 05:19 PM
ok the hub didnt fix the noise. i didnt get to take it down the same route goin to work.
HELP!!!
what else could be makin the noise??
I know its hard to describe a noise by typing but like i said. it almost sounds like mudgripps on smooth asphalt. almost like a bearing in a bind...
I think its coming from the passengers side front wheel. but the resonating in the cab could be making it sound different? But its loudest when taking a left turn doin over 50mph or decel from 60ish to 40mph....
ITS DRIVING ME CRAZY!!
Could it be my tires? or just got a bad hub?? Probably.. thats how my luck goes...
Thanks Guys!!
Old 11-14-2005, 06:56 PM
sleepersilverado's Avatar
possible u-joint.
Old 11-14-2005, 07:45 PM
N5XL's Avatar
Have a look at the rear end and see what the ring and pinion look like. Its starting to sound like the rear end is going out. If you can get someone in the back of the truck and take them for a ride, they might be able to confirm the location of the noise.
Old 11-14-2005, 08:02 PM
CHEVROLET's Avatar
i had same problem i changed the wheel bearings and fixed the problem o h very expensive though
Quick Reply: horrible noise, and annoying..
