How do I replace rotted tie rod and ball joint grease boots?
I'd like to know the awnser to this too. I was able to get a huge universal lower joint boot over the top of the upper boot that was split open. I just covered it up. It fits snug on the top. I replaced the lower ball joints and it came with new boots so i wouldn't know what could be done with those
SPAM HUNTER
The dealer will replace the ball joints, but you will not find a replacement boot, just use the aftermarket 1 over the fucked up factory one and grease it every oil change, it will last...1-2 times a year i would not recommend...its a wear item...its meant to be lubed.
SPAM HUNTER
hmm...you must be a lucky one...
I notice about every other oil change when i lube mine they have dropped down considerably...tie rod boots have holes so its expected, ball joints are fine.
