How do I tell if my 4x4 switch has gone bad?
Old 02-06-2008, 04:27 PM
Originally Posted by Chevy Cowboy
did a search on my trouble code, apparently it means theres a loss of communication with my transfer case, I may need a reflash, a new module or there is a bad connection at the transfer case. Hey torque wrench how much is a new module?
A new module is a couple of Hundred bucks, but I'd try the re-flash firts. Most of the time if the re-program don't fix it, the you have a sensor in the Encoder motor that goes bad and we just replace the sensor and you're ready to go.
My money says, do the re-flash....then replace the sensor if that don't fix it. I'll even help you out with that. After you re-flash it if it still don't correct it....PM me and I'll help you get it fixed.
Old 02-06-2008, 04:41 PM
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
asked a gm tech today what he thought might be the problem whenn I said it was U1026 code/ lost communication with the t-case, he said it could be broken wires, ground, t-case burned up?, tccm, Ill call and ask them about the reflash though
Just a thought, the battery in my truck barely holds a charge anymore especially with the cold weather, everytime I go to start it, it takes a few seconds before it turns over and sounds like it might not, but usually does, could that cause the 4wd problem?
Old 02-06-2008, 08:02 PM
THE-HOE's Avatar
Check your ATC fuse in the fuse box under the hood.. Its the Automatic Transfer Case. that might be a problem.
Old 02-06-2008, 10:06 PM
Piss Pumps for Sale
well I can get a 241 transfer case(manual shift) from a junk yard with only 150,000 KMs on it for 500 bucks, I think Ill just swap my autocrap out and put in the dead reliable floor shift, should be a very easy swap from what I read!!! then all my darn trouble should be gone when I remove the tccm and all the switches eh? Good upgrade also for when I go sas someday
Old 02-07-2008, 07:04 AM
No, that shouldent affect your 4x4 system.
Old 02-07-2008, 06:49 PM
KeukaZ71's Avatar
i had similar problems with my 4wd. it turned out to be the 4wd switch.
Old 02-08-2008, 10:48 AM
Piss Pumps for Sale
its not the 4wd switch, anyways, I think Im gonna go ahead and swap in the Np241 manual shift from the nbs or obs trucks and get rid of the auto trac
Old 02-08-2008, 11:50 AM
THE-HOE's Avatar
did you check the ATC fuse?
Old 02-08-2008, 03:36 PM
Piss Pumps for Sale
thats the one in the electrical center correct?
Old 02-10-2008, 10:53 AM
THE-HOE's Avatar
yes sir
Quick Reply: How do I tell if my 4x4 switch has gone bad?
