How do you lock flt wheel
Working this pry bar
I MUST HAVE MISSED SOME THING , I MORE WORRIED ABOUT WHEN IM PUTTING THE CRANK BOLT BACK ON HOW DO I KEEP THE CRANK FROM TURNING
11 sec. Truck Mod
To get it off like said you can stick a bar cross ways thru the balancer to hold it as you break loose the crank bolt.
To reinstall i use an electric impact, it seats it perfect.
Or you can use the top technique in reverse, its kinda easier with another set of hands.
Or they make a tool that locks to the teeth on the flywheel to prevent the crank from spinning.
An impact gun is the easiest way on and off.
Where are you located, I have the KM starter lock assembly for locking the engine that you could borrow. The hardest part is torqueing the crank bolt when assembling the engine. If you use the GM bolt-uses torque stretch, you set the bolt to 37 ft-lb and torque it another 140 degrees. Many get an aftermarket crank bolt which requires considerably less torque.
Corvette454l88
09-01-2016 01:24 AM
gaps
10-15-2015 02:53 PM
