How high can i rev my 5.3 L33 aluminum block?
hey guys well just had a quick question.. i was reving my engine too 6200 on my 212/218 cam but since i decided to upgrade to a 217/223 on my 5.3 i was thinking im probably going to rev a bit higher.. no matter what happens i will only push it to prob 200 rpm higher then what ever Hp i make max at the dyno. but just had a quick question i had heard something about the aluminum blocks not being able to rev past a certain rpm.. can i get some input on that? thanks..
Yea I c where people r shifting and that's where I would like to shift mine at but heard that the aluminum blocks can't rev too high.. I was trying to c how high is that Max point.. Ive seen iron blocks rev to 7 k but no aluminum blocks..
Where's the Beef?
Looking on LS1 Tech (since they are almost all Aluminum block) I see that a STOCK LS3 has a redline @ 6600rpm. I don't see why your Cammed L33 can't shift at 6400.
As far as I know the Aluminum Blocks have longer cylinder sleeves than Iron blocks do which should allow them to spin higher with more reliability. Someone PLEASE chime in on this.
