How to Remove Valve Covers?
Old 11-16-2011, 09:25 AM
Junkyard Dog's Avatar
Default How to Remove Valve Covers?
Please do not laugh at my stupid newbie question. I am very mechanically inclined, having rebuilt several engines for older (1960s-1980s) cars, but I have never done anything on a modern car but change the oil.
2005 GMC Yukon. 4.8
I want to remove the valve covers and maybe clean out the PCV/orifice on the driver's side valve cover and the fresh air tube baffling under the passenger side valve cover.
On an old car, I would just undo the four bolts and take them off, being sure to have a new gasket ready for reinstallation.
On this 2005 GMC 4.8, though, there are coil packs and all kinds of stuff. What do I need to do so that I can do this without messing anything up? Disconnect the battery? Remove the coil packs (and, if so, how)? Just disconnect the spark plug wires? Is a new gasket needed?
Help me out!
Old 11-16-2011, 09:30 AM
mhotrodscooter's Avatar
Remove the coil packs, the all come off in one piece,the valve cover bolts or under the coil packs..
Old 11-16-2011, 09:43 AM
Ah! See, I told you I had not done this before. LOL! I assume this is pretty straightforward? Also, the smallest metric socket I own is like 10 mm. Small enough?
Old 11-16-2011, 10:00 AM
I have a gauge for that
Atomic's Avatar
I want to say the valve cover bolts are 8mm. There are 4 of them. The nuts holding the spark coils on are 10mm. Unclip the big white connector in the middle, unbolt them and set them aside. You dont need a new gasket assuming the current one is in good shape.
Old 11-16-2011, 10:04 AM
Yes sir... Think it's like 5 10mm bolts. Remove plug wires, unplug the big white coil pack harness. The back bolt by fire wall can be a pain to get out..
Old 11-16-2011, 10:09 AM
Thanks for all of the help, guys!
Old 11-16-2011, 04:22 PM
I went an bought an 8 mm socket, already have a 10 mm, and passed on the new gaskets. Thanks!
Old 10-26-2012, 08:00 AM
Since I have to do this again, I just wanted to thank all the people who answered my stupid questions last time and saved me a lot of time!
Old 10-26-2012, 09:19 AM
nonnieselman's Avatar
Pretty easy after the first time!!!
Old 11-09-2012, 10:42 AM
Talking
Yes, it went a lot faster. I walked back into the house, started washing my hands, and the wife asked, "Wow, you are already finished?"
Took several hours last time. About 45 minutes this time.
No more smoke!
Quick Reply: How to Remove Valve Covers?
