Hydroboost?
Here's exactly what VicLlama told me. He converted his because he's bagged and body dropped on 24's
"Yeah man its pretty simple.. You use your stock lines and master cylinder. Just make sure you get the lines off the 2500 that goes to the P.S. pump. Theres one line that comes off the Hydroboost that you have to Tee off into the return line for the P.S. pump. Thats pretty much it.. "
First, It's best to get a pump from a hydroboost truck, as its got the high mounted return tube, in addition to the low mount. The other thing it has is higher pressure to handle the increased demand. Running a hydroboost unit on a lower pressure pump won't give you the full benefits.
Also, you can buy all your hoses, and it will look stock. (Think about it, would you run a 105amp alternator with a 2000W stereo system?)
I would get new pressure lines from the pump to the Hydroboost unit, and from the hydroboost to the gear inlet. You dont want to pop a hose and burn your truck down.
Hydroboost units increase the stress demand on the system, so make sure your connections are good and tight, and your hoses are A-OK.
Make sure you bleed the system out well.
FIll the P/S Pump of oil to the Add mark on the dipstick
If you've got a Mity-Vac, and a large rubber stopper, pull a vacuum on the top of the reservoir can for around 10 minutes, note the vacuum for leaks.
Release the vacuum.
Apply 5 or so brake applies to cycle and push through fluid in the Hydroboost unit. Slow, full strokes. Re-check fluid level and note the change. If its alot, you just pumped out a decent amount of air. Repeat.
It's the highest point in the system, so it's going to take a bit to get all the air out.
C
Release the vacuum.
C
GMCtrk
18
10-06-2015 03:48 PM
mrgrim
07-08-2015 08:12 AM
