i know someone knows
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA
6.0 LQ9
196/207 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
I got these from this site
http://www.smokemup.com/tech/ls1.php
I think that some of the duration and lift numbers are backwards, I corrected 2 of the duration specs in my list.
peace
Hog
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
2002+ LS6 cam
117 LSA
GMPP Hot Cam
112 LSA
GMPP ASA Cam
110 LSA
6.0 LQ9
116 LSA
5.3 LM7
114 LSA
peace
Hog
2001-2002 LS6....204/211 .525/.525 116
Part# 12560950 $234 from GMPD
2002-2003 LS6....204/218 .555/.551 117.5
Part# 12565308 $234 from GMPD
hog your specs are off, those numbers are not at .05 duration, and some of them are wrong.
Actually those are numbers at 0.050", they are certainly not the duartion numbers at the lash points.
BTW, your year breaks are incorrect, they didnt have 2 different cams for the 2002 LS6 like you have stated, there is only 1. Additionally The 2001 LS6 cam is different than the 2002-2004 LS6 cam.
Looks like we both need to check our sources.
Does anyone here have concrete cam numbers for the GEN 3 engines???????????????????????????????????????????
peace
Hog
OK here we go:
2001 LS6 pn 12560950
207°/217° duration at 0.050" lift
.525"/.525" lift
116° LCA
2002-2004 LS6 pn 12565308
204°/218° dur@0.050" lift
.550"/.550" lift
117.5° LCA
GMPP Hotcam pn 12480033
219°/228° dur.@0.050" lift
0.525"/0.525" lift
112° LCA
GMPP ASA Cam pn 12480110
226°/236° dur.@0.050"
0.525"/0.525" lift
110°LCA
GMPP Showroom Stock Design Cam pn 88958606
239°/251° dur @ .050" lift
0.570"/0.570" lift
These are 100% correct. They are from a GM book.
peace
Hog
.525"/.525" lift
116° LCA
.550"/.550" lift
117.5° LCA
0.525"/0.525" lift
112° LCA
0.525"/0.525" lift
110°LCA
0.570"/0.570" lift
peace
Hog
