I need help,cant get truck to start, no spark
Old 02-07-2009, 12:18 PM
13 Second Truck Club
A Low Dime's Avatar
Default I need help,cant get truck to start, no spark
After swapping on a new intake manifold, I cant get the truck to start. After many attempts of fixing what was believed to be wrong timing or 180* out, I dont seem to be getting any spark at the plugs.
Truck is 2000 4.3 S10
I have replaced all of these: Cap, rotor, distributor, coil, ignition module, plug wires and plugs.(All of these have been replaced AFTER we could not get it running, one by one)
Never unhooked any grounds except the firewall to hood ground, hood is removed. Only thinks unhooked were on top of manifold: Cam sensor in distributor, map sensor, EVAP sensor, coil plug, ignition module, 2 plugs on TB, 2 plugs on A/C compressor, coolant temp sensor.
The coil does seem to be putting out power. I am getting fuel.
Now, with swapping on this new manifold, my injectors are going from 19lbers to 24lbers. Still with stock tune modified by Blackbear performance.
Its getting to a point I will have to pay someone to come fix the truck. I need some help finding the problems. Got some questions, just ask.
Old 02-07-2009, 01:09 PM
Where's the Beef?
viciousknid's Avatar
try the cam sensor.
Silver mod o just had a thread going last week about having no spark. Turned out to be a bad Cam Sensor.
Old 02-07-2009, 10:25 PM
A Low Dime's Avatar
Cam sensor comes new with the distributor.
Well it finally throwing a code, 1351: Coil High Voltage
Did some searching online. Looks like a bad one, everyone that says they have the code cannot find the problem after replacing everything like I have. And everyone that replys to them is baffled at what the cause is.
Old 02-07-2009, 10:29 PM
Where's the Beef?
That's crap. I hope you can get it swapped out.
Old 02-08-2009, 08:22 PM
dlt76028's Avatar
have you tried talking to someone who's done this swap on an s10? check the distributor and make sure its installed correctly.
Old 02-08-2009, 08:25 PM
dlt76028's Avatar
""Well ,I think I got 'er done. By the way I have a 99 Blazer w/4.3. (sorry I didn't mention that).Any how I replaced the coil and all seems fine. I went to the library and got a book on codes, it is called OBD11 Diagnostic Fault Codes by Peter David. It explained alot about the code mystery. I also put on a new dist. cap, rotor,and crank sensor. Next is oil line replacement. Thanks for your help.""
There is a pretty long test to diagnose this code.
Only 2 PARTS could be fault either the Ignition Control Module and or the VCM (Vehicle Control Module).
I will say, though it looks like the wiring from the VCM to the ICM could also be faulty.
It really should be professionally diagnosed as it looks like parts could add up.
found that. try another coil.
Old 02-08-2009, 08:26 PM
Resident Retard
BlackGMC's Avatar
My offer still stands on a gallon of free gas and some matches... I will even throw in so marshmellows to roast.
J/K... I hope you get it worked out
Old 02-08-2009, 08:30 PM
dlt76028's Avatar
http://www.fullsizechevy.com/forums/...p/t-68627.html
make sure that distributer is right.. really important.
Old 02-08-2009, 08:33 PM
Wearin' da big hat
00ChevyScott's Avatar
It might catch on fire on its own with brendan working on it
Old 02-08-2009, 08:34 PM
Resident Retard
BlackGMC's Avatar
Well looks like david is giving him advice now so he is definately doomed... The one time my truck almost cost fire david was with me...
Quick Reply: I need help,cant get truck to start, no spark
