I want to up grade my flimsy tie rods
Old 10-09-2010, 01:22 AM
40series's Avatar
Default I want to up grade my flimsy tie rods
What would be a good up-grade for the stock tie rod end to a bigger one
Old 10-09-2010, 10:12 AM
Praise The Lowered
RibeiroBJJ's Avatar
Moog is usually a good option, But I know in the past when I have installewd a bolt on lift kit from RCD, Fabtech, Rough Country, Cognito etc. They have came with beefier tie-rods and such..check with a few companies and see..
-Or you could easily fab your own with chromoly tubing to sleave o.e rods, and then use Heim's with grade 8 hardware..I have done that a few times
Old 10-09-2010, 10:23 AM
Praise The Lowered
RibeiroBJJ's Avatar
Found these:
http://store.4wheelingplus.com/prodd...p?prod=67-3156
http://www.alligatorperformance.com/...ng-p-3530.html
https://www.lagunaspeed.com/product/...t+Sleeves.html
Old 10-09-2010, 10:34 AM
1Bear's Avatar
As mentioned by RibeiroBJJ, Cognito Motorsports offers upgraded steering components for 6-lug and 8-lug GM trucks.
Old 10-09-2010, 11:50 AM
2004SSS's Avatar
ive done a few lift kits on the gmt800-900 and cognito is one of the better upgrades i found this and installed it on my 3500 with 10" lift and 37's
its pricey but very beefy. the centerlink weight about 50-60 lbs and its solid billet
you use moog tie rod ends with the kit and they are equal to about a 1" fine thread bolt.
not sure if this kit will work on the 1/2 ton trucks .
Old 10-09-2010, 07:30 PM
40series's Avatar
im looooking into some tie rod sleeves to thread over the rods.
Old 10-10-2010, 10:31 AM
southern_chevy's Avatar
Made some for my truck out of chromemoly and teflon lined rod ends. Turns out I have to much of an angle to use them with my truck leveled out. would work good on a stock or lowered truck prolly.
Old 10-10-2010, 12:29 PM
3406a's Avatar
www.rareparts.com
I installed them on my truck after breaking a sleeved set and would never go back.
Old 11-04-2010, 06:55 PM
AndyJ_o's Avatar
Originally Posted by 3406a
www.rareparts.com
these looks sweet. i assume they come in pairs? any problems with em so far? im in the market for some and want to buy something thats gonna last a longggg time.
Old 11-04-2010, 07:43 PM
HoveyBayou's Avatar
I have the Cognito tie-rods on mine. Eliminates the cheesy ball joints and uses a heim instead.
Quick Reply: I want to up grade my flimsy tie rods
