Intermittent A/C Problem
Old 07-27-2008 | 05:10 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Intermittent A/C Problem
It always works great unless I go through an auto car wash or its been sitting for a couple days in the rain. The blower motor works perfect but the little a/c snow flake symbol wont come on. When I press the snow flake symbol to make it blow cold air it flashes 2 or 3 times then goes back off. After I get out on the highway for a couple miles it will work fine again like there is a connection loose or something. Usually it takes 3-4 miles on the highway running 60 for it to start working, if I just drive around town it takes longer. I did find out yesterday that a short burst to 120 showing a mini cooper S that big black diesel trucks can move on out that it will start working much quicker Its a 2006 with the auto climate control.
Old 07-27-2008 | 05:31 PM
ZZebes's Avatar
nice lol
I hope you didn't go 120 with the trailer attached
and you parked it next to the Z71 didn't you, cause that would explain
Old 07-27-2008 | 06:34 PM
jhe2003's Avatar
Same thing happened to me once when I went through a car was, the a/c was not working but the blower kept working. It only happened once so I never found out what happened.
Old 07-27-2008 | 10:15 PM
Grumpy5.3's Avatar
It sounds like your low side a/c switch is messing up.
Old 07-27-2008 | 10:36 PM
1slow01Z71's Avatar
What does the low side switch control in the ac? Im ac dumb, give me a motor and can figure it out but this ac stuff confuses me.
Old 07-27-2008 | 10:53 PM
It's the switch on the accumalator. The big silver thing that gets cold when the a/c is running. The switch shuts off the compressor when the pressure is low in the system. It does not mean you have a leak. Those switches go bad.
Old 07-28-2008 | 09:02 AM
1slow01Z71's Avatar
Thanks, illl take a look tonight when I get home. Atleast I know what the accumulator is
Old 07-28-2008 | 12:54 PM
budhayes3's Avatar
PT's Slowest Truck
+1 on the pressure switch on the accumulator, if it's bad it won't allow the compressor to engage
Old 08-02-2008 | 12:33 PM
eallanboggs's Avatar
If it's car wash or rain related it sounds like moisture is getting into one of the connectors, but once it dries out after you drive the vehicle(either due to heat or air circulating in the engine bay)it starts working again. Try taking it to the car wash and get it wet enough that the A/C doesn't work. Drive it home(slowly) and hit every electrical connector(the ones associated with the A/C) with compressed air ONE AT A TIME. Separate the male side from the female and hit both sides with compressed and then reconnect it. Test the A/C after you hit each connector with compressed air. If it starts working after you have dried out one of the connectors examine that connectors more closely. These connectors are supposed to be WATERPROOF, but after a few years they may allow some water to get by. You may have a loose or damaged pin or a poor crimp. You have to look at both the male and female sides once you locate the exact connector that is causing the problem.
madmann26
04-29-2020 10:17 AM
dsbodley
11-14-2015 10:46 PM
2002_Z28_Six_Speed
10-04-2015 02:34 PM
02AWDAWSDenali
10-01-2015 06:08 PM
sTNT971
09-26-2015 07:27 AM
