Just towed for the first time...My truck SUCKS!!
#22
Originally Posted by GregM
I ran some seafoam through my truck a couple months ago, and it seemed like the truck ran a little better right after I did that. Is there any way to tell if the cats are plugged? I had a tech at the dealership ride around with me not long ago with the truck hooked up to the monitor, and he said everything looked fine. I just get some hesitation around 1400-1700 rpms where the truck seems like its bogging down.
GregM
GregM
#24
Originally Posted by GoldenVelvet
That seems odd. I tow often with my truck and its only got an itty bitty 4.8. I tow a car and tailer to the dragstrip. About 5000lbs with no problems.
#25
Originally Posted by slowec
You need to find a backpressure gauge. you screw it into the precat o2 bungs.Anything over about 3 psi @2000 rpm will start killing performance.A high reading before the cat and a 0 psi reading after the cat is a cat restiction.If before and after readings are high, the muffler is clogged.
Suburban2500
07-19-2015 04:50 PM
07NBSChevy
20
07-08-2015 07:27 PM
