keyless entry
Old 08-03-2008 | 03:12 PM
dimedsbc's Avatar
Default keyless entry
I bought my truck brand new in 2006 it had auto locks and man windows... when i bought it it did not come with keyless entry, if i bought the remotes would i be able to just program them and they would work?
Old 08-03-2008 | 03:28 PM
2005 Silverado's Avatar
SPAM HUNTER
some trucks come with the stuff for the keyless some dont. you have to have it vin checked.
Dustin
Old 08-03-2008 | 03:40 PM
dimedsbc's Avatar
so you know what spot in the vin to look for?? what code would it be and would it not be located in the glove box with those codes?
Old 08-03-2008 | 03:48 PM
SBTork's Avatar
au0 is the rpo code for keyless entry. I don't think it's as easy as getting a key fob and programming it on these trucks. I know the rke(remote keyless entry)module is the passenger side window/lock switch on trucks that have keyless entry. I would think that if you don't have power windows, with that switch/module, it won't work.
I may be wrong though, check your local dealer to see if they can try it and see what happens.
Old 08-04-2008 | 12:16 PM
If you have the RPO option code AU0 in you glove box RPO lost, then you can just reprogram the fobs. Otherwise you're **** outta luck.
Old 08-04-2008 | 12:30 PM
LS1GMCTruck's Avatar
what does fob stand for?
Old 08-04-2008 | 02:04 PM
viciousknid's Avatar
Where's the Beef?
FOB is a term for shipping Freight On Board.
KEY Fob is basically another term for key chain or a device on a ring or a chain, for ease of tactile identification, to provide a better grip, or to make a personal statement. A fob may be symbolic or strictly aesthetic, but it can also be a small tool. Many fobs are small flashlights, compasses, calculators, penknives, discount cards, bottle openers, or USB flash drives.
It just so happens that now days we have Electronic Key Fobs that allow use to lock or unlock our cars/trucks.
Old 08-04-2008 | 06:26 PM
sv650lex's Avatar
Just call the local dealer and ask the parts dept. if your truck has it. They will ask for your vin # and tell you. Took me about 30 seconds.
Old 08-05-2008 | 09:41 AM
Thumbs up
Thats what I appreciate...A great definition or explanation. Thank-you viciousknid.
Old 08-06-2008 | 09:03 PM
Mighty Whitey's Avatar
12 Second Club
I didn't know the RPO code for KRE, but on my '02, the fuse panel lid said "if equipped with power locks w/o remote entry, 30amp fuse is used (in the specified spot), if equipped with power locks w/ remote entry, a relay is used"
I got 2 keys with my truck, and a swift kick in the ***, and that's all.
I figured it SHOULD have had the remote entry, but wasn't sure.
what's the secret to programming a remote for a NBS truck??
