Knock sensor (help)
There is a code for the rear sensor and a code for the front sensor, if both codes are set then it most likely is caused by the wire harness/connectors on the harness. In my case it only throws the rear knock sensor code so thats all i really have to replace but i figure while im in there and spending $100 on new intake gaskets i might as well replace both sensors and the harness.
