Lets end the weight misconception
Old 03-29-2010 | 10:42 PM
  #21
00ChevyScott's Avatar
Wearin' da big hat
Where in my post do you see me saying anything about power to weight ratio....
Old 03-29-2010 | 10:45 PM
  #22
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Even 800 pounds going from a 2wd-4wd? seems kind of steep, considering the transfer case and front differential are aluminum. transfer case is probably about 75lbs, axle Im not sure but I cant see it being more then 200lbs, drive shaft, 20lbs? misc electronics for it to work approx 20 lbs? CV shafts another 20-30 lbs. Torsion bars cant weight to much more then springs, we do have an extra crossmember, but I cant see the weight difference being more then 400-500lbs
Old 03-29-2010 | 10:47 PM
  #23
Dewey's Avatar
you're forgetting the front axle
edit: whoops... thanks for catching that.
i dunno about our trucks, but the axle for an isuzu pup weighs about 185 lbs.
Old 03-29-2010 | 10:53 PM
  #24
_zebra's Avatar
makes children cry
he mentioned that
and i weighed a couple weeks ago - 4780 with a full tank & me. that's a RCSB 4x4 with not a lot added. i can't wait to get some aluminum wheels, though. that'll cut 36 unsprung lbs right there
Old 03-29-2010 | 10:55 PM
  #25
EVILGMC's Avatar
i remember reading or hearing something...every 100lbs is about 10hp at the wheels.
Old 03-29-2010 | 10:56 PM
  #26
dlt76028's Avatar
your forgetting to read thoroughly.
And I agree with chevy cowboy, 400-500lbs max.
Old 03-29-2010 | 10:57 PM
  #27
fastnblu's Avatar
I never knew what to guess when comparing 2WD - 4WD or AWD. I figured at least 3-400# at minimum. So 4-800 should cover that.
Also, goin from RC to EC. It's prolly yr dependent, since some came w/. 3 or 4 dr design, or added inches. My guess is 2-600#. So, I figure 3 or 400 is a good number there. Anyone?
Or RC - EC - CC? What's accepted there as common?
Old 03-29-2010 | 11:01 PM
  #28
Dewey's Avatar
the funny thing is i read over the post 3-4 times to make sure he actually didn't say anything before i pointed it out... i guess i'm just dyslexic.
Old 03-29-2010 | 11:03 PM
  #29
dirt track racer 81's Avatar
After seeing this thread, I think Im going to put my truck on my longacre scales I use to scale my race car with... Ill get left, right, front, rear, and cross weights and percentages.
Old 03-29-2010 | 11:06 PM
  #30
RedHot04's Avatar
My question is, how can there be such a huge fluctuation in race weights?
ANSWER:
Originally Posted by fastnblu
Cmon, seriously? There's 24pgs. on this just in drag racing section. Rather than everyone post up their weights, I think you're just tryin to decipher the wild swings.
It varies by:
-cab config. & length ( w/in that, step- or fleet-)
-drive:2, 4 or AWD
-chassis/ frame (1500/ 2500, etc.)
-axle setup (10/ 14 bolt)
-yr (which would create changes i.e. block material, safety content, yada yada)
-engine block material
-power adders (all add wtg)
-exh (hdrs or manis, catbacks, duals, dumps, exits & their materials)
-tranny (A or M, 60 series, 80E, 5/6 spd & their capacities)
-different body panels & their materials (cowl hoods, rollpans instead of bumpers, cladding i.e. SS) fiberglass vs steel
-interior trim levels
-bed cover material (soft, hard, liners)
-tires/ wheels (sizes & materials)
-drums/ discs (& their sizes)
-suspension changes (drops, lifts & not just how they're done but materials)
-gas level & fluids
-deleted parts
-extra bits (stereo eqpt, subs, misc. crap)
-driver (ya, it's not part of truck, but it is goin down the track)
-Last but not least, when we've swapped parts (efans, alernators, trannies. Not just the parts themselves, but whatever we took out/ added to make it work)
I may've left a few items/ generalities out, but that should cover a majority of ideas.
What exactly are you confused about? What is the concern about this weight misconception you speak of? The question of race weight is obviously related to how quick/fast you are or aren't. Everyone has a different setup period... Beyond that when it comes to race weight AND times, its about weight to power ratio...
