Little white smoke at idle
Coolant has gone down and im getting a little white smoke ate idle.could this be a intake gasket leak or a cracked head and how will i know w/o pulling the heads
Pull the spark plugs first, look for one with white calcium buildup. If you find one (or not) pull the affected head(s). It will be fairly obvious from there if a cylinder has a leak or if the gasket went bad.
Get a machine shop to pressure test the heads to see if there are any cracks present. Now is also a good time to get the heads milled and ported.
if i have no calcium on the plugs then its the gaskets
so if theres no calcium on the spark plugs then it a bad gaskets?
Post a video. You're in Michigan, it's winter there, and white smoke from condensation in the exhaust is normal. The last thread like this one turned out to be normal when the OP finally posted his vid.
An enormous cloud of white smoke is a different story.
