lq4 w/ 243's..what head gasket? ls1 or lq4?
cant find a thread stating what head gasket should be used..im thinking a lq4 headgasket should be used since the bore is bigger then the ls1 headgasket or should the headgasket match the combustion chamber?? not 100% sure tho...
HomerSimpson (12-03-2021)
lq4 with 243
Hi i'm new in this,i have a swap in my old chevy short bed 90,i already put on this truck. 2001 lq4,schoenfeld longtubes headers,comp cam 595-598 lift-281-283 232-234,92mm tb intake from 2008,60lb fuel injectors,electric fan,3000-3200 stall converter with 4l80e,corvette servo,shift kit,3.73 posi rear end,tuned by khp,275/50/17 rear and 255/50/17 front. I drive everyday like 40 miles.
My cuestion is can i use 243 heads milled to .030,what head gasket i need? Works better or not ? I'll apprecite yours repply. Thankssss
slowlsx
08-10-2015 05:33 PM
