Ls1 swap in 98 gmc sonoma
Old 02-13-2005 | 02:20 PM
exxxllr8's Avatar
Default Ls1 swap in 98 gmc sonoma
i was wondering if someone could help me find info on what i will need to swap my 4.3 with a ls1 any info would be GREATLY APPRECIATED
Old 02-13-2005 | 03:57 PM
hellbents10's Avatar
LS1Tech Sponsor
Money and time. You can get mounts from JTR. Then the stock radiator wil work to a point. Headers will have to be custom made if you want a decent set thats better then manifolds. You need a imput shaft and bellhousing from the LS-1 too. A custom harness will be in order too.
Old 02-14-2005 | 09:33 PM
exxxllr8's Avatar
will the stock4L60e trans bell housing and input shaft work or does it just need to be hardened also i have the harness for all the engine sensors i do need a pcm do they make a aftermarket one and would you know wher i can get these items ill need
Old 02-14-2005 | 09:49 PM
Flyer's Avatar
The LS1 style input shaft on the trans is different than the others, as well as the bell housing bolt patern. I would bet you would do best by buying a busted trans off an f bod or truck.
I just recently bought a 90 model s10 for this very reason too. Mine will be more race oriented though.
Old 02-14-2005 | 11:55 PM
exxxllr8's Avatar
WHAT DO YOU MEAN ? THE 4l60e trans i have is the stock one that is in the truck.are you saying that the one i have wont work
Old 02-14-2005 | 11:57 PM
LS1Tech Sponsor
Right, you would need to get the bellhousing and imput shaft from a ls style motor 4l60e
Bluecollar Hotrods
06-11-2024 11:37 PM
Denali08
08-09-2015 04:34 PM
creekrat
08-02-2015 01:27 AM
Black-Syde
07-06-2015 02:12 PM
Quick Reply: Ls1 swap in 98 gmc sonoma
