MAP sensor signal wire advise.
Truck in my sig, 2 bar MAP, SD tuning already done...
If I tee in a wire to the signal output wire of the MAP, will it effect the reading going to the PCM at all? If it does, is it enough to harm anything?
I assume not because people must do it all the time to activate meth kits, but I am using it to read MAP on an Aeroforce Intercepter Scan Gauge.
Any advise? Thanks!
Any advise? Thanks!
i am not familiar with the gauge but I thought its whole song and dance was it got all that info from the OBDII port. You have a link to its instructions.
Most meth kits use rpm and boost as the "triggers" to my knowledge. Boost being just a hobbs switch and rpm being "T" tapping into the pcm's rpm wire in most occassions.
And I thought that some meth kits were triggered off MAP sensor, but I could be wrong.
Anyone else?
Originally Posted by thunder550
My meth kit came with its own extra 2-bar sensor that teed off of the boost gauge.
Originally Posted by Mort
Can your gauge be modified to read the 2 bar map correctly? I think you need to modify the gauge to recognize the map signal as 2 bar and not 1 bar.
I just don't understand. If you hook up PC with HP Tuners to OBDII and read manifold pressure to limit of 2 bar MAP, then why can't the Aeroforce Guage do the same?
How do I change this text
Originally Posted by m7 rocket
I wish. If anyone new how, please let me know. Aeroforce is saying just hook to analog. I want to use the manifold PSI that is already there!
