MAP sensor signal wire advise.
Old 10-20-2006 | 01:34 PM
Mort's Avatar
Cool
Originally Posted by m7 rocket
PID??
PID = Parameter Identifier. That is what is referred to when describing sensor inputs such as TPS and MAP. They have designed one that will read the output from the map to a 2 bar scale vs the stock 1 bar scale.
Not sure how you are going to get your gauge to do that unless you can hook it up directly to a vac/boost source on the intake manifold or modify the scale used by the gauge. Propably not going to do it if it is not set up for it.
someotherguy
11-08-2017 07:46 PM
natejk
11-15-2016 09:05 AM
chvy=power
10-20-2015 10:08 AM
Pontiac Derek
09-19-2015 02:49 PM
creekrat
09-10-2015 01:59 AM
