Miles between oil change
Old 11-13-2011, 05:06 PM
chevz7102's Avatar
Question Miles between oil change
I was wundering how manny miles people go between oil chaing on there 5.3l or any gen 3 vb for that matter my truck has 3700 miles on the oil and the oil life monitert still says about 55%. im going to get the oil chainged tommarow eny way. last time I went over 3500 miles thay said the oil looked a litttle dark. what say you guys.
Old 11-13-2011, 05:43 PM
Kemble's Avatar
Looking at your oil will tell you nothing about its condition.
Old 11-13-2011, 06:41 PM
chevymec's Avatar
I use Mobil 1. I will change the filter and add 2 quarts when my low oil light comes on since that is about 3-4k miles. The next change will be oil and filter both.
Old 11-13-2011, 06:43 PM
Dewey's Avatar
I run M1 extended and change the oil and filter every 15,000 miles or 1 year; whichever comes first. 99% of the time, I drive just over 5k/yr, so I just change it every January.
Old 11-13-2011, 06:53 PM
nonnieselman's Avatar
I change mine when the oil change light comes on. Well when it comes on i just find time and then change it.
Ever 3000 mile stuff is rediclous. More like 7500-10000miles or so with good oil. Wont hurt to change the filter half way.
Oil last quite awhile now a days.
My brothers 6.0 had over 300k miles on it in 6 years. Changed the oil and air filter every 10k miles. Still had compression in spec at 350k when the next guy got it.
Truck weighed 10,200 lbs and still got 11mpg.
Old 11-13-2011, 07:28 PM
Resident Retard
BlackGMC's Avatar
I use mobil 1. I cahne my oil every 6000 but i change the filter every 3000 and top off the oil. Mine never uses any oil, it is always full.
Old 11-13-2011, 09:22 PM
MikeGyver's Avatar
Ever 3000 mile stuff is rediclous. More like 7500-10000miles or so with good oil. ...
Me, too. Mobil 1
Old 11-13-2011, 09:59 PM
SnakeOiler's Avatar
Mobil1 - change oil and filter ~6000 miles.
241000 total miles. Heads looks brand new without a hint of buildup or staining.
Old 11-14-2011, 01:24 PM
LS-Powered's Avatar
Conventional oil - 3000 miles.
Synthetic- 5000
Old 11-14-2011, 01:37 PM
whitedakota's Avatar
I use castrol gtx 10-40 and change mine every 5000-8000 miles. Ac delco pf61 filter at the same time.
Quick Reply: Miles between oil change
