My interior rattles so bad
Old 12-05-2008, 12:43 AM
nonnieselman's Avatar
Mine use to be nice and quiet... now im tryin to figure out how to make the exhaust quieter,,, then all the sqeaks are goin to get louder... ill just turn the radio up, its a truck not a luxury car.
Old 12-05-2008, 12:48 AM
GMCtrk's Avatar
I want to have my cake and eat it too!
Old 12-05-2008, 02:45 AM
magnetized's Avatar
I've got a couple of rattles, nothing really major. I'm about to throw a whole bunch of sound deadener in there though, should do the trick.
Old 12-05-2008, 02:47 AM
Hunt&Fisherator
silver-mod-o's Avatar
Go thru and tighten things up... A little foam insulaton and tightening of screws does wonders. That's why mine has ZERO squeeks due to old age.... Dynamat helps too. I plan on putting some down while I have the carpet down. It will cost a few bucks but if you want it like new it can be done... Replacing door gaskets in the 99-00's does wonders too....
Old 12-05-2008, 03:52 AM
GMCtrk's Avatar
I was wondering about the doors, whenever I hit a bump it almost sounds like my door isn't closed all the way. I've also had passengers thinking that their door wasn't closed either when it actually was. Guess I should look into those door gaskets.
Old 12-05-2008, 04:18 AM
Where's the Beef?
viciousknid's Avatar
My dads truck does that. does it leak air?
The only problem on mine is I need weather stripping on the driver door and the passenger rear window leaks air. Everything else is fine.
Old 12-05-2008, 08:37 AM
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
I dont mean to sound like a dick, but stop complaining, strip down your interior, reassemble it making sure all screws are tightened very well, and as far as your door clunking like its not closed its probably your door pins going, open the door and pull up on it from the bottom see if you can feel any play in the hinge
My truck is a 2000 and i offroad it and it sees some abuse, and I only have 1 rattle at the moment to track down
Old 12-05-2008, 08:53 AM
Neil 6.0's Avatar
Location: as far away from Koonerville as humanly possible
Rattles? Go ride in a 97-02 Ford or Dodge with 80K+ miles on it. Your truck will feel air-tight after that.
On that cupholder, take it off and run a thin bead of silicone on the backside of the metal plate, like making a rubber gasket. Let it dry then put it back on. Lube the hinge while you have it off.
Old 12-05-2008, 09:18 AM
shandy294's Avatar
Mine just starting making noises like that a few weeks ago after driving 14 miles on a dirt road in Big Bend park. I hate stuff like that,too.
Old 12-05-2008, 11:58 AM
PT's Slowest Truck
budhayes3's Avatar
My truck has has squeaks and rattles since day one, but I figure, eh, it's a truck. There's one real bad rattle on top of the dash, right in front of me, that was driving me nuts though. I pulled the radio bezel and took a look...turns out that a little plastic tab which is part of the dash, that secures into a slot, had cracked and broken of the dash. Doesn't bother me much now that I know what it is....and since I can't afford a new dash pad right now lol.
Quick Reply: My interior rattles so bad
