Need an 8.1 Vortec with Manual Trans VIN
Old 08-04-2009, 02:22 PM
69MyWay's Avatar
Default Need an 8.1 Vortec with Manual Trans VIN
Anybody know anybody...or happen to have a 2500 - 3500 with the 8.1 Vortec and MANUAL trans?
I need a VIN from this set up to program my 8.1 that will be in a 69 Covette with a Richmond Six.
I have found tons of auto trans models, but no luck yet on the manual.
If you have this...please shoot me a PM - the VIN will only be used to have the GM cal pack loaded in my PCM for the intial tune.
Old 08-04-2009, 02:33 PM
Neil 6.0's Avatar
Location: as far away from Koonerville as humanly possible
Does it matter which year model?
Old 08-04-2009, 05:57 PM
69MyWay's Avatar
I think as long as it is a drive by wire - standard shift - 8.1, it will be okay. The harness is set to run as a 2002 style silverado - we have to make some minor changes to the harness. The throttle body is the 2003 and up single plug design, but I have the jumper harness to convert to the two plug earlyier model.
Old 08-04-2009, 06:37 PM
Neil 6.0's Avatar
I could be wrong, but I think all the 8.1's were drive by wire. Anyways, here's some links to some I found on Autotrader, just borrow the VIN from there.
http://www.autotrader.com/fyc/vdp.js...standard=false
Click on the pics & carfax check to verify for 8.1/6-spd.
Old 08-04-2009, 07:05 PM
69MyWay's Avatar
You ROCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-05-2009, 08:08 AM
Neil 6.0's Avatar
Glad to help. Sounds like a kick *** project. Let us know how she runs.
Old 08-05-2009, 08:31 AM
69MyWay's Avatar
Neil...great info...and I never thought about Autotrader.
I can't open autotrader at work - so will do some more search.
I just talked to the programmer - to make the harness and computer work, I need to find a 2002 or older 8.1 - so now the field gets really small. The newer ones use a 1 meg system that is different and he can't load the service pack.
***EDIT****
Yep...the first and last one there are 2001 - ALL IS GOOD!!!!!!!
Old 09-26-2009, 12:19 PM
xx_ED_xx's Avatar
Old thread, But I had a similar issue. But i needed the TAC module gas pedal etc. So I just went with a megasquirt set up
Oobray
06-13-2022 03:38 AM
Blackrat48
08-16-2015 11:56 AM
thewrx
08-12-2015 08:28 PM
grantpo
07-15-2015 12:21 PM
Quick Reply: Need an 8.1 Vortec with Manual Trans VIN
