NEED HELP: '04 Silverado remote 12V+ hook up???
Originally Posted by seal20
Been doing some research...it seems these 03-04's don't have a remote at the back of the radio either, they use a relay type turn on or something...What a PITA!!!
Are you adding an amp to the stock deck?
If it is just to power the sub then all you need is a 12v ignition simulator.
Stinger makes one called an LVT2 or DEI makes one but I forgot the part #.. Find a Peripheral or DEI (Clifford/Viper) dealer and you can get one for about $10 or so.
Tore up my 2004 Silverado and have everything hooked up except I can't find a good 12V+ remote hook up for the amp...tried the cigarette lighter but that's a constant...Please help, I need to know a good hook up. Thanks! - -Carlos
Originally Posted by vortec327
How are you hooking up your amp? are you using a high level inputs (speaker wire), or are you using an adaptor low level input (speaker wire adaptor to low level RCA's)?
