need help with crankshaft question
i have a 2006 6.0. im not too sure if it has a reluctor wheel or not..i found a remand. 6.0 crank on ebay for cheaper then i coudl get mine machined and was going to just go that route. but the one on ebay is a 58 tooth. it has a solid wheel, my 6.0 crank has 2 gears that look staggared..question is, will the 58 tooth work? its going in my 2003 1500 in place of a 4.8.
If the Machine shop has the tool, the reluctor wheel can be changed out.
i decided to just get my factory crank machined. $75 bucks. isnt too bad..but could anyone tell me what reluctor wheel size is on this 2006 6.0 crank? and what size would of been in the 2003 4.8 that was in my truck from factory? are they the same?
They should both be 24X
Also the the balancing is different for each Engine Size and it should be re-balanced accordingly.
