Need help with my wheels! 22x10 guys please
alright....
right now i have 22x8.5 wheels with 265/35/22 tires. the rear are getting done to 22x10 and im not sure which size tires i need in the rear. id like to keep them the same height or SLIGHTY bigger. ive been recommended different sizes by everyone. 285/35 295/30 305/30 315/30 which one is it? keep in mind id like them not to be crazy expensive either....
thanks!!!
thanks!!!
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
First, lets look at what the numbers on the tire size represent.
265/35/22
265 is the width in mm
35 is the sidewall height in a percentage of the width
22 is the wheel size.
Here is the formula: 265/35/22 = roughly 3.65" sidewalls (265mm x 35%/ 25.4 to get inches).
285/35/22 = roughly 3.92"
290/30 = roughly 3.42"
305/30 = roughly 3.6"
Keep in mind this is a rough estimate to finding your sidewall height as final height can vary by manufacturer. Your best bet is to use the information above to get you a few size options, then go to your local tire place to get final specs(height) on the sizes you are looking for.
I have 285/40/22 on a 9.5 inch wheel, and I think my tires are 31.4" overall height. I would have to confirm that though, which I can do on tuesday if you need it.
Hope that helps.
265/35/22
Hope that helps.
lxcoupe
07-21-2015 02:12 AM
