new fuel setup for 04 returnless to return
its not really a hto wire kit but it gets power straight from the battery and uses relays from the stock wires to activate them. so the voltage is constant. i had a magnavolt on it bu ti didnt think i need one with the dual pumps. there was a speacial 56 pin connector i used for when i need to remove the tank though.
I'll post pics later, I'm getting ready to go out the door. But....your bucket looks slightly different than mine. My bucket sits directly on the bottom of the tank (as far as I can see), but yours has those little nubs on the bottom to space it up, so the sock isn't smashed against the bottom of the tank. You have the Racetronics set-up, right? More later
Looks like mine would smash the sock if I left the sock stick out of the bottom of the bucket.
See more pics
under Returnless Fuel Module Observations in the Engine and Exhaust section
lxcoupe
07-21-2015 02:12 AM
GMCtrk
07-17-2015 06:39 PM
04, 53, banshee, converting, fuel, install, lines, performance, plumbing, return, returnless, rwturnless, setup, silverado, supply, trucksnet
