New problem...........wierd
Originally Posted by moregrip
Both of my key fobs don't work anymore. I changed out the batteries thinking that might be the fix but still nothing. Any ideas?
Ah ha, you work in MRI at a hospital? I do and i have erased my badges a million times from forgetting to take it off cause its a huge magnet in there. The girl i work with erased her key fob the same way. I know its not likely this is your problem but i just sharing anyways. lol
Originally Posted by kdirectorate
I'd call the dealer. ...but don't give them any money. I'm sure they deal with this sort of thing all the time.
Try this Grippy. If it doesnt work you may have to see the dealer-----
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
1-Close all the vehicle doors.
2-Insert the ignition key into the ignition lock cylinder.
3-Press and hold the door unlock switch.
4-While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5-Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6-Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
7-Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
8-Operate the transmitter functions in order to verify correct system operation.
Grippy, where is the welding class? Is it near a military base? Have you tried it at different locations? Sometimes some of their/our radars and radios screw with the fob signals. Mine never worked on base in Dahlgren and certain parts of NAS Pensacola.
