nitrous activation buttons for the steering wheel.
Old 10-10-2004, 10:31 PM
vanillagorilla's Avatar
Hey 02 Denali, have you thought about using an 03+ steering wheel with all the radio controls in it? I don't know if you have one, but if you don't then use the radio controls for all your switches. Very sleeper and stealthly too! It can't be that hard to do, just run all the wires trough the column.
Old 10-10-2004, 10:39 PM
Deckhand's Avatar
02den, what you can do is use the setup using the WOT switch. Then launch at full throttle (while its disarmed), and when you get moving, 4500 rpms or so, flick the Arming switch, and you will complete the circuit.. as you are already pedal to the metal.. and you'll spray.
Old 10-11-2004, 06:05 AM
Formerly one92rs
one03sierra's Avatar
Talking
yay that sounds good. i am going to order the rpm switch today and go that way. builders---transmission builders is who. when you put it in low it engages the reverse clutch pack and the forward pack to help reduce wear on the tranny. ill see if i can get it explained better. hell with a built 4l80e i shouldnt have to worry about it.
Old 10-11-2004, 08:55 AM
You say that when you put it in low, you mean first gear right? It engages both clutch packs, but is that true only for the 80e, what about the 60e? What about 2nd and 3rd gear? This is pretty interesting, I've never heard this before. I might have to put a ratchet shifter in my truck now!
Old 10-11-2004, 05:35 PM
Formerly one92rs
Talking
hey vanilla they are telling me it is only for the first gear launch. after that second and third are different. i thought it was funny to untili started asking. and it holds true for the 80 and 60e's.
Old 10-11-2004, 06:39 PM
Banned
if it engages reverse and 1st gear it would be a transmission brake. in which case you would be able to stall the thing higher when it was in 1st than if you had it in D and tried to stall it. it'll be a bit harder on the transmission to use that technique if that is infact the case (doubt that it is though) and you will end up breaking parts sooner using that method.
Old 10-11-2004, 06:48 PM
Formerly one92rs
Exclamation
i will get it perfectly right for you z28. that way you can quit telling me it is wrong. do you build transmission?
Old 10-11-2004, 07:00 PM
GoldenVelvet's Avatar
Originally Posted by Z28Maro
...if it engages reverse and 1st gear it would be a transmission brake...
That is true.
Ive always thought it was better (more consistent) to put it in 'D' and let the trans do its thing. Maybe line pressure is high in low, reducing slip, and thats why its better for the trans.
Chewy07
11-14-2015 09:46 PM
dsbodley
11-14-2015 09:46 PM
turbo6c3
10-05-2015 06:11 PM
Blklgt
09-28-2015 03:21 PM
gavin2005
09-13-2015 09:04 PM
Quick Reply: nitrous activation buttons for the steering wheel.
