O2 sensors- bosch or gm
Old 06-20-2011, 09:33 PM
Calbo's Avatar
Default O2 sensors- bosch or gm
Tranny went down again and while it is out thinking of replacing the o2 sensors. The ones from GM are about $60 a piece and the Bosch are $32 each from Rock Auto. Any difference beside price? Going to do all four.
The truck has ~48K on it and ~40k blown. I'm not throwing any o2 codes but thought it might be good PM while the exhaust is out as I drive the truck like I stole it.
Old 06-20-2011, 09:35 PM
Resident Retard
BlackGMC's Avatar
Get the gm ones. I went through 3 sets of the bosches then switched back to gm
Old 06-21-2011, 08:18 PM
Chevy_King1500's Avatar
GM! sparkplugs.com is where i got mine!!
Old 06-21-2011, 08:25 PM
Bigschwerm's Avatar
GM.... i went through a set of bosch before i swapped back to gm.
Old 06-22-2011, 03:16 AM
DR132's Avatar
another vote for the GM's...you'll likely spend more in the long run with the lower end O2 sensors
Old 06-22-2011, 10:15 PM
Dont waste your money. I have them come through the shop all of the time with triple the miles you have on those and still functioning perfectly. Leave them alone until you have a problem with them.
Old 06-23-2011, 09:06 AM
blueflamed03's Avatar
question:
Can one or more start going down, lowering power and gas mileage, without a code?
Old 06-23-2011, 11:48 AM
GM has 02 fail detection pretty damm sensitive. If the PCM see's a sensor not responding correctly they will set a code fairly quickly. If one is failing to the point of effecting gas mileage and or power you will have a MIL and code.
Old 06-23-2011, 11:49 AM
cool, thanks, just saved me some cash!
Old 06-23-2011, 12:44 PM
TX Tahoe Z71's Avatar
GM, but I wouldn't replace them just to replace them.
Quick Reply: O2 sensors- bosch or gm
