odd wind noise when open sunroof
Old 01-15-2012 | 11:05 PM
50kta's Avatar
Default odd wind noise when open sunroof
when i open the slideing sun roof i get a " pulsing " noise kind like a helicopter sound at almost any speed.. it is almost painfull to my ear drums? it is almost like the cabin of the tahoe is preasurizing and de-preasurizing. its a 2001 tahoe its a factory sun roof. any ideas..
Old 01-16-2012 | 12:37 AM
4.8whipple's Avatar
crack open another window...
Old 01-16-2012 | 01:53 AM
Suburbazine's Avatar
Check the vent caps at the rear of the truck. If you have aftermarket vents or the originals are clogged with debris, you will have cabin pressure issues at most speeds with windows open.
Old 01-16-2012 | 10:14 PM
50kta's Avatar
how do i check them and where at the rear?
Old 01-17-2012 | 09:25 PM
See the black plastic grille things on the rear door pillars? Those are the cabin vents, they go through the pillar inside by the rear windows. I've seen people cover them up with chrome or silver covers and it plugs up the interior of the car.
Sometimes if the car is sealed really well the fresh air function of the HVAC will slow down at the vents with the windows closed vs the windows open.
Pressure Relief Valve Replacement (Utility)
Removal Procedure
  1. Open the lift gate.
  2. Remove the outer quarter panel upper applique.
  3. Remove the upper rear garnish molding.
  4. Remove the corner rear garnish molding.
  1. Depress the locking tab on the back of the pressure relief valve to remove from the rear of the vehicle.
  2. Remove the pressure relief valve from the vehicle.
Old 01-18-2012 | 12:43 AM
50kta's Avatar
sweet thanx
Old 01-24-2012 | 01:16 PM
BigKID's Avatar
It is called buffeting. My Tahoe does it too with only the sunroof open (not when cracked) or only one of the rear windows is open. The air is also very turbulent with only the front windows down. Rolling down the rear windows relieves both the buffeting from the sunroof and reduces the front turbulence. I am also going to check the function of the rear vents to see of there may be a blockage there.
Old 01-24-2012 | 09:35 PM
Something I forgot to mention is that there should be a popup spoiler on the sunroof. When you slide the glass back does a spoiler pop up at the front?
00loudchevy
12-03-2015 05:54 PM
lukn4trbl355
10-21-2015 11:19 PM
JordanH
10-03-2015 03:59 PM
Infernohoe
48
10-02-2015 10:25 PM
Velocity1
10-02-2015 08:01 AM
Quick Reply: odd wind noise when open sunroof
