Oil Cooler or no Oil Cooler
I hate my cats
I scored a 34 inch rad from an 09 for 100 bucks. It has the factory oil cooler on the left tank. My concern is if I spend the money at the stealership for the lines and thermostat to make it work that I'll someday be driving my lowered truck in a field or something and snag the lines and kill my engine. Can and should the oil cooler tank be blocked off? Or has anyone ever seen it used to cool any other fluid? Thanks.
Owen
Owen
PT's Slowest Truck
Creederado (used to post here all of the time) bought a 34" rad that came with the oil cooler ports in the radiator that he didn't use and he just plugged them off. You really could just leave them open as nothing will leak out of there, but then you might get some junk in the ports. Plastic or rubber plugs will suffice, or brass or even plastic threaded plugs are a little cleaner looking.
As Roger mentioned, if you do decide to install the oil cooler the lines are tucked up enough that they won't snag anything.
Vortec350ss
01-12-2016 10:36 PM
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
09-25-2015 12:36 PM
