oil pump bolt specs
oil pump bolt specs
I bought a stripped short block and need to know the size of the oil pump bolt...the one that holds the pump to the block..went with a double roller chain so i had to put the spacer...can go to the stealership but wanting to go with ARP....arp lists most of the bolts by application just not that one
Thanks
Thanks
Ferocity02
07-17-2015 07:05 PM
