Overcooling Transmission
Old 12-25-2012, 01:17 PM
  #21
dirtydeeds's Avatar
can't you just run it thru the radiator AFTER the cooler? Then it'll preheat the fluid, but never hotter than the radiator.
It just seems like the tranny would need to be hotter than 100?? But idk
Old 12-25-2012, 02:05 PM
  #22
1994Vmax's Avatar
If that was the case not one vehicle I own, or anyone else in this province owns would have a transmission in it...... because they would have failed due to cold. We only get maybe 5 months of the year that are warm and the rest are anything but.
It doesn't matter, period.
Old 12-25-2012, 03:11 PM
  #23
skeet's Avatar
id never run through the radiator in a modded truck or vhechicle, specially after blowing the intercooler of the radiator took out a fairly new FLT
Old 12-25-2012, 03:57 PM
  #24
Praise The Lowered
RibeiroBJJ's Avatar
One more time , you can NOT overcool a transmission....
Old 12-25-2012, 08:04 PM
  #25
TOWN CRIER
cheyenne383's Avatar
Originally Posted by ak2007r6
Just food for thought. Truck is usually never parked outside but due to some recent event's I had my truck parked outside for two days in a parking lot and this morning I went out to start it and drive back to the house. Outside temp has been below 0 for a while and the trans temp read in the negative teens this morning. I put the keys in and let it idle for about an hour (got sidetracked and idled longer than planned). Trans temp was 140 when I came back and quickly cooled down to around 106 after a few minutes of driving. Shifted great (didn't romp on it to much). Will be doing this over the next few weeks sadly.. might be time to switch out my truck for the wife's ride.
Mine sits outside up here and I've seen the trans temp as low as -30 when I start it up... I definitely let it warm up for 15 minutes or so but it hasn't complained so far.
Old 12-25-2012, 11:18 PM
  #26
dmelvin's Avatar
Originally Posted by Baderic
I think if you are using the factory bunch gauge to watch trans temperature,then 100 degree peg should actually be 160. The needle on the trucks never budges until 160 even though it is labeled 100,210,260.
I'm using an Aeroforce Interceptor.
Old 12-25-2012, 11:46 PM
  #27
nonnieselman's Avatar
Your the reason i tell everbody to just skip the factory radiator cooler.
Ive seen it happen several times.
Water and ATF mixed arent exactly good for a transmission
Old 01-02-2013, 08:55 PM
  #28
dmelvin's Avatar
I know this thread has kinda died. But I wanted to add something.
I was driving down the highway in my NNBS W/T, I went to check transmission temp after thinking about this thread, and to my surprise it read 100*... If GM didn't put a bypass in their transmission cooler, I fail to see why I need to.
calsdad
06-14-2023 11:07 PM
bearden86
26
11-15-2015 03:58 PM
dsbodley
11-14-2015 09:46 PM
nabozny21
10-17-2015 07:47 PM
jscherbs
09-30-2015 07:54 AM
Quick Reply: Overcooling Transmission
