override the headlights
Old 08-17-2005, 07:07 AM
JayBirdWs6's Avatar
Default override the headlights
I have a 99 Silverado. When i start the truck up in somewhat dark time in the morning with the sun about to come up my headlights come on along with taillights. I push the override button to override the headlights to turn them off and it doesnt work. In my old company truck it would chime and turn off along with my moms 00 blazer is work chime and turn off the headlights. It doesnt even chime when i push the button a couple of times. Anyone know what the problem is?
Old 08-17-2005, 10:37 AM
How do I change this text
Wilde Racing's Avatar
Override trick don't work on 99's.
Old 08-17-2005, 11:35 AM
JayBirdWs6's Avatar
there wouldnt be a kit for it would there?
Old 08-17-2005, 11:53 AM
curlyws6's Avatar
There was a trick using a resistor on the auto headlights that I used on my 2000 S10 Blazer. I don't recall the specifics of it but it worked very well. The light sensor is on your dash.
I had the same problem that when I was driving to work I ran in and out of sunlight showing through the roadside trees... light on / lights off / lights on....
Good luck!!
Old 08-17-2005, 12:46 PM
PT's Slowest Truck
budhayes3's Avatar
You can use a resistor or diode to bypass the ambient light sensor (which is a photodiode). I used an LED and wired it in right at the BCM which is real easy to get to, by the steering column under the driver's dash lower finish panel. I posted up some info and a copy of the schematic HERE
Old 08-17-2005, 02:06 PM
JayBirdWs6's Avatar
Thanks budhayes3, I'll try that and see what happens. Thats all foreign to me being that i dont know crap about these trucks or the electrics
Old 08-17-2005, 04:34 PM
graystepside's Avatar
does not work on the 99's. DAMN!!!
Old 08-17-2005, 08:38 PM
StrokerAce03's Avatar
Or you can engage the e-brake one notch. It isn't enough to engage the brake but it turns off the lights; providing you do it before you start the truck.
Old 08-17-2005, 09:49 PM
z7199's Avatar
I wired up a toggle switch to go through the resistor and to not so I have Auto headlights and OFF
Old 08-18-2005, 07:06 AM
JayBirdWs6's Avatar
There's no way to use the 2000 - 2002 auto headlight stuff whatever it is? There has to be an easy fix just pop something in.
Quick Reply: override the headlights
