P1415 Error code
Old 11-10-2009 | 10:14 PM
muscleboundlss1's Avatar
Default P1415 Error code
Just picked up a 2000 suburban 1500 (5.3 w/ a whipple) and it just threw a code the other day... P1415 Emissions (air pump?) any suggestions on what to look for or replace?
Thanks
Old 11-10-2009 | 10:52 PM
viciousknid's Avatar
Where's the Beef?
according to a google search for P1415 you need to replace the Air Check Valve on the driver side. I THINK it's on the manifold but I dunno.
Old 11-11-2009 | 07:53 AM
DUDE!.. I've must have looked at every wrong page the other night. Thanks for the tip--- I'll take a look!
Old 11-11-2009 | 06:27 PM
budhayes3's Avatar
PT's Slowest Truck
Yes, if it's the same setup that they used to use, there will be an air injection pipe setup going to each exhaust manifold, and branching out into one pipe extension per primary. Where the hose screws on to the pipe setup, there used to be a check ball in there. Sometimes they would either stick or start to rattle...my old 85 MonteSS used to have a problem where one of the check ***** would rattle for a few seconds as the engine came up into operating temperature.
Old 11-12-2009 | 09:57 PM
Thanks again... i haven't had time to look at it, but i just took the truck out and the SES light went off. At least i know where to start or what to change this weekend.
thanks again...
Pimpinpete
43
12-22-2017 09:13 AM
00loudchevy
12-03-2015 06:54 PM
Avalanche2002
11-30-2015 08:31 AM
bearden86
26
11-15-2015 04:58 PM
Pimpinpete
09-08-2015 08:39 PM
