p1516
That would be the throttle body. Check the yellow wire which is the signal wire for a break. Should be within about 4-5 inches of the connector if the wire is broken. If it is broken you will see a light colored spot in the insulation and if you bend the white that spot will pretty much turn white and maybe just break right open. There is a bulletin about it out on the 05s and it seems like it applied to the older ones as well.
well I put my new computer in yesterday and this morning I was on the way to work as soon as I set my cruise control my truck went about a mile and then it did the reduce engine power crap again
Another reason throttle by wire is just pure idiotic. You don't see a throttle cable setting codes now do you? I once asked why and I was told TAC is lighter, less moving parts, less to go wrong. I don't know that I've ever even heard of a throttle cable going bad and a cable weighs what, half a pound maybe. The TAC pedal assembly, all the wiring, the module and so on probably weighs 10-15 pounds. I just don't see the logic. Throttle cable > TAC
metalm0
32
09-11-2024 10:12 PM
GreyChevy
07-07-2015 08:57 PM
2K Silvy
06-06-2015 01:22 PM
darkirish63
05-01-2015 02:17 PM
foxySS
04-06-2008 12:00 AM
