Please help.. Why does my TB look like it caught fire?
Originally Posted by 04BlackGmc
lmao looks like yes but Oring not gasket,
Originally Posted by greentahoe
The gasket on mine stayed in place on the manifold and looked good so I left it. It took me quite some time to get it clean. I used soapy water and a toothbush, scrubber, and even a flathead screwdriver!!! Im just now going to get started on the porting. Wish me luck!!
I still cant believe how bad it looked behind the blade. It was unbelievable!
Laughing my *** off...
i ment yes look like yes the forst fire **** is from the EGR.
Originally Posted by 900Z1
EGR makes it dirty. I've cleaned mine 4 times in a year.
I will delete it when my HPTuner arrives.
Originally Posted by koochingchang
how do i clean my tb?? i have used seafoam but i poured it through my brake booster line..
usually a toothbrush and carb cleaner works fine. then a clean clothe. hard to get behind the blade unless you remove the entire TB. if your gas pedal sticks every so often, then you can get by just by cleaning the TB w/o removing it
Velocity1
09-22-2015 01:32 PM
