Power windows goin slower.
PT's Slowest Truck
Try a little spray silicone on the window runs first before you replace the part. The regulators are a common problem, but the cable usually snaps when they go bad. I've been using silicone on my window runs as a band aid for replacing the regulator for about 3 years now...every time one or both of the windows start to slow down, I clean the window run (rubber part that the window rides in) with a rag, then spray some silicone with a straw down the channels, and on a rag and wipe down the exposed rubber. So far, the windows have returned to a quicker speed every time (about every 3-4 months). You're gonna get some residue on the window itself, but it will come off with some windex.
PS..the window run is the rubber part around the window...don't put anything on the belt mouldings (the felt type weatherstrips on the door and door panel), as that will leave a residue that will coat the window and drive you nuts.
Going to have to try the spray myself. Ever since I replaced my passenger side regulator it has been really slow and the colder it is the slower it is about snail pace at freezing. Also how would one go about rewiring it?
PT's Slowest Truck
so just put some spray silicone on the front and rear sides of the window? where the glass rides its way up?
PT's Slowest Truck
Yeah forgot they were wired through the BCM it might just be that my passenger side is worn out it was replaced a year ago but it was just a cheap ebay part but I'll give th silicon spray a shot first thanks for the advice.
Superman09
09-25-2015 05:55 AM
b4z
09-10-2015 06:58 PM
