question about alternator pulley
Old 04-06-2008 | 01:50 PM
GTOsRamairSilverado's Avatar
Default question about alternator pulley
recently i installed an underdrive pulley and a new alternator pulley. my question is should the new alternator pulley be smaller or bigger than the stock pulley. the one the came with the package that i bought is bigger than the stock one but i have heard of some people getting a smaller one when they have bought theirs. the brand that i bought is asp if it matters any.
Old 04-06-2008 | 02:03 PM
thunder550's Avatar
High on diesel fumes
It should be smaller to keep the alternator speed up with the smaller crank pulley, which slows the accessories down.
Old 04-06-2008 | 02:23 PM
Mangled03gmc's Avatar
Baltimore Whore
John
Old 04-06-2008 | 03:56 PM
mine was bigger than the stock one, which would probably explain my low voltage
Old 04-06-2008 | 08:54 PM
Truckshop's Avatar
asp sells an underdrive and an overdrive pulley or the alternator. you can buy the set either way.
Old 04-06-2008 | 10:22 PM
whats the difference in the underive and the overdrive pulley for the alternator????
in the set that i got it says: "ASP 25% Underdrive Crank Harmonic Balancer Pulley & 23% Underdrive Alternator Pulley, 1999-2004 GM Truck"
Old 04-06-2008 | 10:28 PM
mbell's Avatar
you want an overdrive alt pully not an underdrive
Old 04-06-2008 | 10:35 PM
the overdrive alt pulley is smaller than the underdrive alt pulley??
Old 04-06-2008 | 10:38 PM
xchevyx24's Avatar
YES! the smaller the pulley the faster the alt will spin= more voltage.
Old 04-06-2008 | 10:40 PM
OK OK !!! LOL
